Re: Simultion of "robot" for Mu
Dont understand your question. tried what?
For example : on other objects in project i can click on right mouse button and choose "edit custom attributes" but on the CSC i cannot use it, and have msg "It is impossible to open an object, since it has an encrypted open handler".
I use educational license, a problem precisely not in it?
like most of the library objects, the CSC dos not have the feature of accessing the custom attributes through
pressing right button.
Therefore I posted a work around to use / create user attributes - as you questioned - by using
the methods obj.createAttr(...) / obj.setAttrValue(...)  / obj.getAttrValue(...) to use user attributes.
@ examples
have you looked at the CSC demo (s.b.) in the plant simulation examples ?
@ user attributes.
yesterday you posted :
I can use the dialogbox, but i cant use/add user attributes
Therefore you should know what you need any user attributes for.
I just highlighted a workaround to handle user attributes
