Size of frame
I`m using Tecnomatix Plant Simulation 11. I`m trying to put a CAD model as a background of the frame but  it is too big. If i chage the scale of the CAD model then i dont have the real distances at the frame.
Is there any possibility to make the frame bigger?
Thanks.
Re: Size of frame
you can scale the layout. than you need to calculate the scaling factor for the frame (meter per pixel).
Just take a reference in the layout, measure the distance in pixel (icon editor) and calculate the scaling factor. Than the distances in the frame have the right values also when you scale the layout.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
