Slow Speed
Builder
Builder
I am using a student license and a normal laptop for modelling.Problem is that the model Run very slowly.Extremely slow.I try to run the model for 30 days but it takes really long time to run even for 7 days.Is it a computer problem or some modelling error.i dot get any error,but i want to make sure that my way of modelling is not reducing the speed.Can i get rid of this by increasing the RAM of PC???
7 REPLIES 7
Re: Slow Speed
This can be caused by many factors. Can you share the model in question?
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Re: Slow Speed
Builder
Builder
i dont know why its happening,also i am new to simulation so hard to find.i a attaching the model below..please tell me the soln.
Re: Slow Speed
I cannot analyze your methods, but the model is running quite fast on my computer.
To speed up the model on your computer, you could delete the animation line in the buffers, this slows down the simulation (with MU-animation), if you create the batches.
For longer experiments you should deactivate the MU-Animation.
The processor-speed is more important than the size of your RAM (at least for this small model).
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Slow Speed
Builder
Builder
u mean to say that i should activate STEP OVER ANIMATION EVENTS in the event controller.is that right? or is there other way to delete the animation line in buffer? if not then please tell me how to do that??
Re: Slow Speed
Builder
Builder
i found the answer .Thanks!!!!
Re: Slow Speed
right mouse click on the buffer in the class libray --> edit icons --> change in the animation mode
--> delete all
Steffen Bangsow
web: www.bangsow.eu
Re: Slow Speed
Builder
Builder
that was very helpful!!! Thanks!!!
