Sollaborative work of several workers
Hello I am doing the examples of the Bangsow book and I have a problem with the 9.4.5. I don't understand the function of the @.move located in the last line of the setProcTime method. If I eliminate it the simulation doesn't work properly and if I write it an error appears.
1 REPLY 1
Re: Sollaborative work of several workers
You call the method twice, one time as exit control of the source (this is right) and as entrance control (before actions) of the single proc (this is wrong).
You need @.move if you use a exit control front to move the part.
Because of the waituntil in the method, you cannot use it as a entrance control.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
