Source Control : Create a wave of MUs
Hello everyone,
I'd like to create a wave of entities every x seconds.
For example every 120 sec create 5 Entities in one go. We can do it thanks to a method which be called every 120 sec and create 5 Entities on a Buffer . But can we do the same by configurating the Source object ?
Thank very much !
BR
O.C
Re: Source Control : Create a wave of MUs
You can set MU selection to Sequence cyclical (or Random, Percentage) and activate Generate as batch. You need to select a table and specify 5 in the Number column.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Good job Mr. Nomden.
Thank you very much.
BR
O.C
