Statistics report (Chart)
I have a main frame in which I have a "station" which contains many proccesses inside
(I dropped a subFrame in the main Frame so the 2-D Layer appears to have
only a machine when really it does many subproccesses inside the subFrame)
What do I need to do to Show a condensed variable of some of the items of the subfunction (see image attached) on the Chart tool (statistics report) and not every process individually.
Re: Statistics report (Chart)
Hi Jerogaro,
select multiple objects and drag & drop onto a newly inserted Chart object. Plant Simulation asks you for the Statistic Type. Select Resource Statistic. You get a chart with stacked columns.
Another way to generate a statistic is to select multiple objects and click the right mouse button and select Show Statistics Report.
There is a third possibility:  Prepare a frame, how it is described in the Example Collection and drag & drop this frame onto a Chart object. Please look at Catagory Information Flow > Tipic: Statistics of a Frame. You can try multiple different evaluations.
Peter
