Stochastic simulation
I like to model a stochastic model in Tecnomatix, but I don't know how  to include the stochastic nature in the machine selection when we are having similar kind of machine and i don't have a clarity on how to input the random values in the system
Re: Stochastic simulation
I'm not exactly sure what you mean by what you wrote, but in the Plant Simulation Help there is an entry called 'Simulating Random Processes' that will probably be able to get you on your way.
Hope this helps!
Kind regards,
Good morning sir,
I am having number of similar machine to do same kind of process in my model. the part from previous station what to go to any one of the machine (station), i need to make this machine selection process stochastic in nature it should select the machine randomly based on availability of the machine and also i want to model the breakdown of the machine also in stochastic
