Stochastic simulation
I need to know the basics of stochastic process modelling. I am trying to develop a manufacturing system with stochastic nature but I don't know the basics kindly help me with it
3 REPLIES 3
Re: Stochastic simulation
what kind of stochastic behavior do you need to model?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Good morning sir,
I am having number of similar machine to do same kind of process in my model. the part from previous station what to go to any one of the machine (station), i need to make this machine selection process stochastic in nature it should select the machine randomly based on availability of the machine and also i want to model the breakdown of the machine also in stochastic nature
if you assign failures to a machine (e.g. as availability and MTTR) the time between the failures and the failure duration is already randomly distributed; the exit strategy cyclical (non blocking) selects the successor depend on their availability;
so you can model your task with the basic functions of Plant Simulation
Steffen Bangsow
web: www.bangsow.eu
