Suggestion
I have an assembly station where the parts are being manufactured. So my current scenario is how should I put the user defined attributes in the parts, lets say a robot drops the part in the same station after the operation is done how can I put the attrinutes in the part saying that this machine already worked on this part?
And also do we an option of 7th axes robot (robot on rail) in Plant Sim because I could only see pick & place robot.
Thanks in Advance!!!!
