Syntax error
Can someone tell me why I get this syntax error in version 13 but not in version 12?
Thank  you!
Kbohara14
3 REPLIES 3
Re: Syntax error
you need to deactivate "New Syntax" in Tab tools
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Syntax error
Hello Kbohara14,
The only explanation I have is that you have turned on new syntax for this method. Please check the setting on the Tools ribbon category.
Ralf
Re: Syntax error
Thank you, that was exactly the problem!
