System time (Windows 7)
Builder
Builder
Hi all,
Is there a function to retrieve the system time (windows clock), during a simulation (datetime or time format). for exemple to measure the length of a run and compare the performances of 2 different methods for the same model...
Re: System time (Windows 7)
sysDate
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Or you can use 'processTime' to just get the CPU time of the application.
So your measurement wouldn't be influenced by other processes.
Ralf
Ralf,
This function is not documented, nothing in the Help-pages.
Gert Nomden
