Table file that ships parts using a method
Hi Everyone,
I am trying to use a method to move parts from my warehouse to my customer (in this case is a buffer called Customer) using a table file called shipping schedule. I would like to move a quantity of parts to the customer but I am having a hard time writing the method could someone please help. I will attach some screen shots of the shipping schedule and the method I am trying to use.
Thanks in advance!
Kbohara14
Re: Table file that ships parts using a method
Hi!
Here's an example. You did not tell which version do you use, so here's a screenshot and a model in v.12
Note that the table should be sorted by date, otherwise scheduling will not word correctly. That's why I sort in in Init method.
Regards, Vladimir.
Hello Vladimir,
Thank you for your response, it worked perfectly!
I apoligize I am using version 12.01.
I have another question...After I ship parts to my customer I want my assembly line to be triggered to build from a build schedule, is this possible?
Again thank you!
Kbohara14
Sure, you can call a control, which would either open/close entrance to certain object (EntranceLocked attribute) or create a new part ".MUs.Entity.create(Station1)" depending on what is more convenient.
Regards, Vladimir.
