Tecnomatix Plant Simulation 11TR3 released
Dear Plant Simulation community,
the new technical release Plant Simulation 11TR3 is out!
One of the new features is the new report object:
The 11TR3 release is available for download from the GTAC full product download section:
https://download.industrysoftware.automation.siemens.com/download.php
Would be great to get some feedback in this forum!
Ralf
17 REPLIES 17
Re: Tecnomatix Plant Simulation 11TR3 released
Siemens Creator
Thank you so much, Ralf and Plant Simulation Team.
Is there any example and presentation for new objects, "Fluids"?
Additionally, how can I make 'valve' object?
Best regards,
Franz
Dear Franz,
thank you very much for your positive feedback. Please find attached a small demo model for the fluids. It’s a model of a beer brewery, so has lots of fun with it.
Regarding your question concerning the valve object: Currently there is no valve object, you might use the “entrance locked” and “exit locked” attributes of tanks and mixers to open and close the object.
       My Plant Simulation is cracked when I open the model, I don't know why.
Hi dongshui8558,
can you please check if you have the latest driver for your graphics adapter installed?
Our 3D engine requires some new OpenGL features which might not be available in older drivers.
If this solves your problem, it would be good to know which graphics hardware you have and which version of the driver you had installed.
Ralf
Ralf
Siemens Creator
  Congratulations Team!!!
    I loved the new HTML object, pretty easier and new very nice look,
    I will study better the new fluid library.
    Maybe something easier to Dialog creation in future versions . ...
Best Regards,
Renato Lima
Tecnomatix Brazil
Hi Ralf,
I have tested it and it still crashed when installed the new driver of graphic card, which I use is NVIDIA Quadro 1000M.
Thanks.
Hi dongshui8558,
can you please tell me the version of the graphics driver you are using?
We will try to reproduce your problem.
Ralf
Ralf
Another question:
Does this crash only occurs when loading a specifi model?
Or does it also happen when you create a new model and then start 3D?
Ralf
Hello Ralf,
It only happend when I open the model you upload, which is Beer_Brewing_model_Plant_Simulation_11_3_09_Experiments.spp ‏8347 KB.
