The last row of a column in a tablefile
Builder
Builder
How to find the last row of a column in a tablefile. Now I know I can use tablefile.yDim to denote the last row of the entire tablefile, but how can I denote the last row of, e.g., column 2?
thanks
Re: The last row of a column in a tablefile
If you have different number of entries in the columns, you can use the method find to look for the first empty cell (value=void) e.g. for column 2:
tableFile.setCursor(2,1);
--look for empty cell
tableFile.find({2,1}..{2,*},void);
local rowNumber:=tableFile.cursorY;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
little extension
find searches only until tableFile.yDim, if the next empty cell is located in a new row, the method find returns false, so the following extension:
if tableFile.find({2,1}..{2,*},void) then
-- below yDim
else
-- new row
rowNumber:=tableFile.YDim+1;
end;
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
thanks
This works too, and saves 2 lines of code. lol.
if tableFile.find({2,1}..{2,YDim+1},void) then
-- below yDim
end;
Well, in that case, you could also drop the IF-clause (because in yDim+1 a VOID will definitely be found) and save another line ^^
tableFile.find({2,1}..{2,tableFile.yDim+1},void)
However, note that you could get into trouble if you have limited your table-dimensions (rows, more specifically) and maxYdim = yDim, I guess you'll get an error when searching to yDim+1 then Smiley Wink
____________________________________________________________
Alex Dilg, Consultant at SimPlan AG (www.SimPlan.de)
This post was good and/or helpful to you? Please provide some Kudos, thank you!
I like the way you think Alex Robot Very Happy
There is an attribute to get the specific column Ydim.
The attribute is 'GetColumnYdim'.
Syntax:  <Path>.getColumnYDim(ColumnNumber:<integer>)
Eg.: TableFile.getColumnYdim(1);
Thanks & Best Regards,
Abhilash Sridhar
Mercedes Benz R&D India, Daimler AG
Neat! When did they add this method into the software? Probably with Plant 12.0; I started with Plant 9 and up until 11 this did not exist. Seems I need to read the release notes more carefully ^^
I thought I saw that in the help at one point... but I could not for the life of me, find it!
Thanks!
