Total driving time of a transporter
is there a way, to see the total driving time of a transporter?
I found the ready time and the empty time.
But it would be nice if i have the value for the driving time
for example:
-drive and takes a MU, bring it to a buffer (counting the time)
-no available MU, the transporter stops (don't counting the time)
-MU is created, get it up (counting the time)
and so on..
Thanky for your help and best regards
Re: Total driving time of a transporter
see
statTranspWorkingTime
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
i implemented the print method and indicated the the console.
I got some values. I tried to understand the values, but in my case (driving time of my transporter) the values didn't make sense...
Should I have to adjust or something else?
I just want the total driving time of my transporter in the simulation.
Could you find my mistake?
Best regards
it is not the "right" Aufzug. The adress points to the aufzug in the class library. You need to adress the aufzug in your frame (e.g. weg.inhalt...)
Steffen Bangsow
web: www.bangsow.eu
i have to indicate to the used transport.
so that be my code: " print schacht.aufzug.statTranspArbeitsZeit;"
schacht=track;aufzug=transporter...
But i don't understand where i cant find the drinving time Smiley Sad
Or do i understand it wrong?
try
print schacht.inhalt.statTranspArbeitsZeit
schacht.inhalt returns the "aufzug"
Steffen Bangsow
web: www.bangsow.eu
i have absolutley no idea what i make wrong
this is not the right output, what is your endSim-method ?
one hint: stop the simulation, mark your lift and press the key F8
Then have a look into the stat... attributes, look for the attributes, that Plant Simulation fills with data.
Steffen Bangsow
web: www.bangsow.eu
thanks i found the right attribute with f8. But in connection i have another question. With the start of the simulation, the source initiate the transporter. And the simulation runs for 2 hours. So the statTransArbeitszeit should be 2 hours, but after the simulation, the value isn't about 2 hours.
It is just 1 hour 57 minutes and 30 seconds. Whats about the other 2,5 minutes?
Best regards
the remaining time is waiting time (while you stop the transporter) see statTransWartezeit
Steffen Bangsow
web: www.bangsow.eu
