Transporter failures
Good morning all!
I have some small questions regarding failures:
1. I want to model multiple failues on one transporter and toggle those failures active/inactive individually using a method, is this possible?
2. Is it possible to use a distribution for MTTR?
3. It is maybe better to model failures using a self created method? If so, what is a good approach for this?
Thank you for your help!
Kind regards,
Niek
Re: Transporter failures
@1 have a look at object.Failures.NameofFailureProfile.active = (true/false)
@2 Probably you are already using an Erlang-distribution for MTTR -> double clic on the distribution
to see the distributions.
@3
Only if the provided distributions are not accurate enough and
will have a major impact on the simulation results.
You can gather the failure time stamps and create
a distribution that describes the individual failure profile. See the the Statistical Tools Library
Hi Simulator,
Major thanks!
Kind regards,
Niek
