Trigger with Method
Hallo ,
i write a small program to test the trigger function. Using trigger i want to call a method in every minute. And by the method i want to write the vaule of a gloable varable in a table. (In furture, i will read the value of an attributte of transporter and write it in table.)  I get an error in simtalk:trigger.PNG
 It seems that none variable can be used in method.... WhySmiley Sad
Re: Trigger with Method
Please read,
the method caller is handing over  2 string parameters !
this code works
param str1, str2 :string
print "[",str1,"]","[",str2,"]"
variable:=variable+1
Tablefile["Time",variable]:=EventController.SimTime
Tablefile["number",variable]:=variable
