Trying to create MUlti-container system
Hi all experts,
I am getting some unknown index err. Please help me solving err in consumption method on sensor .
Thanks in advance.
Re: Trying to create MUlti-container system
you need to activate the row index in the table partData. Then you need to write the part names into the column 0 (row index). Only then you can use the part name as row index (consumption:=partData[@.name ,tank]  )
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
two problems:
- you need to set a distance in the generator for calling the delivery method
- the assignment of the reserve tanks is wrong: the reserve tank for B1 is B2 and for B3 is B4
Steffen Bangsow
web: www.bangsow.eu
It is working fine . Thanks.
