Turntable has a problem help
as below picture,the turntable I clear check box "blocking",but when the successor  is empty,the turntable  do not move the mu to the successor,  I  do not know why,  see my attachment  ,who can help me ,thank you very much微信图片_20180728155019.png
Re: Turntable has a problem help
the assembly station causes the problem; you want to assembly 2 parts from predecessor 2, but you have set in the entrance interface of the frame the exit strategy to cyclic (blocking), so the predecessor 2 will get only one MU for each main-part. If you change your assembly list (only one MU from predecessor 2), than it works.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
