Two lane track length does not change
Builder
Builder
Hello Community,
I have observed a weird problem with the two lane track in my model. When i tried to change the length of the track by filling the new number in attributes tab, it does not change.
For example I make the length 20 instead of 10 but the length does not increase.
can anyone let me know what is the reason for this?
Re: Two lane track length does not change
do you have a checkmark in curve - transfer length
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
Hi Steffan_B,
Yes, I have a checkmark in the curve-transfer length.
what does it signify ?
If I change it now ,will it have any effect on other parameters ?
Builder
Builder
also, I I use the line, How i am able to change the length of the line even if the Transfer length is selected ?
hard to say, what is wrong, the icon will not change if:
- if you uncheck transfer length; the "physical" representation of the track doesn't change, if you change the length
- if you use an icon (curve is deactivated)
Steffen Bangsow
web: www.bangsow.eu
if you havent solved the problem can you post a sample model.
Sachin
