Unloading from line
Hi, i have a small problem. I have line, where I load something to containers at first ( I use transferstation for this)
and next I need unload the entities from containers. I need not unload in one point (sensor, end of the line), but
anywhere on the line. (first in first out goods go from line to Vyst if Vyst and Prac is free (occupied = false)).
Thanks for advice
Re: Unloading from line
sounds not realistic, but you could do the following: make a fifo table of the parts (e.g. entrance of the singleProc), then you can move them directly to Vyst (maybe you need to wait until the location of the part is a container), after moving the part, delete the entry
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
