Update install issue
Hi Sim Superusers,
I am getting an pop up message while update installation and I tried couple of times and did not work. Please see attached for the message.
Would appreciate your help.
Thank you!!
Re: Update install issue
Siemens Creator
I would first make sure Plantsimulation isn't runing in the background.  Then reboot computer.
Then try to install.  If you get the same error, there may be a permission problem going on.  You should be able to install several versions of Plantsimulation at the same time.
Got you. It looks like a permission issue. You are right.
Thank you!!
