User defined attribute changing
We simulate production line and we have different materials and inbox quantity.
We using delivery table to generate material boxes and we want to change our user defined attribute inbox quantity for the same type of  material but they vary according to production planning.
I attached the table that we use.
Re: User defined attribute changing
Hi @The_Skidders
You can use the last column of your table to create/set user attributes to your MUs. Take a look at the attached model to see a small example.
Best Regards,
Paulo Araujo
