User-defined attributes for TableFile?
Hi community,
Can anyone give me a tip on how to insert user-defined attributes to a table file?
As far as I know, I can only disable the inherit format of it. I can't find where I can do that thing.
Please help. Thank you so much!
9 REPLIES 9
Re: User-defined attributes for TableFile?
Open the TableFile --> you will find the user defines attributes in the Home-ribbon --> User defined
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Or right click on the TableFIle and select 'Edit User-Defined Attributes' and it will open the same dialog.
Thank you Mr Bangsow. It works!
Thank you for your suggestion, Mr JamesM. But only the method of Mr Bangsow works.
Hello Alano
That is strange, guess it might more be a differance in the version of Plant Sim that we are using as I have only used the more recent versions.
JamesM
Yup, I guess so, Mr JamesM. I'm using Plant Simulation version 12, student license Smiley Very Happy
By the way, can you please tell me where I can find the EKanban in the library? I want to create entity in EKanban and I looked into the Kanban library but I can only find .ApplicationObjects.KanbanObjects.BasicObjects.
not the .ApplicationObjects.EKanban.MUs. as I expected.
Thank you so much!
do you refer to one of my examples ?
http://www.bangsow.de/detail.php?id=561
There is no EKanban library in Plant Simulation.
Steffen Bangsow
web: www.bangsow.eu
Yes it is, Mr Bangsow Smiley Very Happy I'm struggling to find my way around Plant Simulation and I have to admit it is very difficult as I have no background about programming. Still I'm learning and trying (with little progress, yup).
Actually I care more about the bin kanban system but it was based on your example so I'm afraid if I jump right at it I would not understand it for leaving out important information along the way. That's why I guess I should take a look at this example ...
Thank you. I will download your file and study it. I hope you don't mind if I continue to raise stupid questions about it Smiley Happy
don't hesitate, you are welcome
Steffen Bangsow
web: www.bangsow.eu
