Using Crane
Hello Guys !
How can i using the crane ? Semeone can send for me a exemple ?
Because i tried but dont work. Thanks a lot !
4 REPLIES 4
Re: Using Crane
go to the start page of Plant Simulation
--> small examples
Category: Libraries
Topic: Cranes (or Cranes and more)
There you can find several examples.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Using Crane
Why is this error character?
Re: Using Crane
you would need to drag the crane unto he storage area to assign the crane to it. Otherwise there is currently no crane assigned to the storage area.
Kind regards,
Igor
Re: Using Crane
there is an error in the library, I have corrected the error
(the attribute storingPortal is not set --> init method of the StorageArea)
Steffen Bangsow
web: www.bangsow.eu
