Using a Trigger object
Can anyone please fix the model i am attaching and explain what was wrong. I just want to run a method periodically every 7 days for 365 days. But it looks like, i am not able to put all the parameters in it.
Sachin
4 REPLIES 4
Re: Using a Trigger object
Hello Sachin,
it works how it is shown by the attached model for Plant Simulation 12
Peter
Hi Peter,
Thanks for your reply. But I am not able to to download any attachment. Infact i am not able to download my own attachment i attached yesterday. Is there anything wrong with this site. Were you able to download my attached file?
Sachin
Sachin
Hello Sachin,
I want ot describe the solution.
The Active Interval is 365:00:00:00 and the Period length is 7:00:00:00.
We select the checkbox Repeat periodically.
On the tab Actions we deactivate the inheritance of Method and insert the name of a method object.
I recommend to register the calls by the following method:
param a,b:string
TriggerActions[1, TriggerActions.ydim+1] := eventcontroller.simtime
TriggerActions is a Tablefile object the first column of it has the type time.
A Reset method contains
TriggerActions.delete
Peter
Thanks Peter.
I knew it was a simple solution. They should totally replace the period with interval. Its confusing.
Sachin
