VSM library not accessible
Hi there,
I am using Plant Simulation 12 (Professional version). I wanted to use the vsm library, but then an error message appear (attachement). How can I download or activate the library?
Selim
Re: VSM library not accessible
The VSM library is not part of the professional license. You need a special VSm license.
GG
GG
