VSM modelling_material flow issues - throughput stops at a certain process
Hi!
I have an issue with my VSM simulation model related with material flow. Some of the process objects does not generate any throughput, although I assign avaliable simulation time. The automatic report does not show any inconsistencies in the model.
In attach I am sending the sim model, so please check it out at your conveniance.
Thanks.
Re: VSM modelling_material flow issues - throughput stops at a certain process
The model material flow stops at the first processing object and does not continue onto the next one. It only fills up the WIP in the sequencing buffer. I've attached a preview.
Do someone knows the root for all this happening?
Many thanks,
Marjan
