Value Stream Mapping
Hi all,
Does anyone have any examples of value stream mapping in Plant Simulation? I couldn't find any small examples within Plant Sim.
Re: Value Stream Mapping
Siemens Legend Siemens Legend
Siemens Legend
attsached you find a small VSM sample model where you can see the effect on warehouse content depending on the number and/or size of used Kanban cards.  TThe demo model is in V13.
For commercial Plant Simulation seats you need the VSM library license. If no VSM license is available you can run the model in viewer mode only, without model modifications...
Best regards
gepi
