Video flicker when use camera animation
Dear experts,
I used 3D viewer to export camera animations, there are lots of flickers in the videos, is there any approach to reduce it?
another question, when i open the shadow for frame, it looks more realistic, but some corner or bottom is quite dark, is there any function to change the brightness of shadow ?
Thanks a lot and Best regards
kevin
Re: Video flicker when use camera animation
The quality of video recording heavily depends on the codec that is in use. I heard of xvid bringing good results - if not available on your machine, look on their website (xvid.com) for more details.
About shadows: There is no such setting. However, it might be that the darkness in a particular corner comes from the background ramp. If you open the 3D properties dialog of your frame and go to the page "Background", you can define a background ramp there - maybe this helps.
