Warehouse exit method
Hello all,
I'm new to Plant Simulation and I need to model a warehouse of a factory.
The warehouse receives receives many quantities of n different parts (in my model there are 10 different parts/entities). As the warehouse receives parts, it has to supply parts to an assembly line in a given sequence.
What I want to do is to instruct the warehouse to supply parts in that given sequence.
I know that I have to use the "Method" object but I don't know how.
Can anyone help me?
Thanks a lot.
João
Re: Warehouse exit method
Hi João,
the arrival of parts is caught by an entrance control. In the attached model a random arrival process is used. The desired sequence is contained in the Tablefile Part_Sequence. The next needed part is stored by the Variable object neededPart.
The code of the entrance control can be:
 Inventory.delete;
?.contentsList(Inventory);
Inventory.setCursor(1,1);
if Inventory.findAttr({1,1}..{*,*},"name", Part_Sequence[1,neededPart]) then
local PartObj:object := Inventory[Inventory.cursorX, Inventory.cursorY];
if PartObj.move(Drain) then
neededPart := neededPart + 1;
if neededPart > Part_Sequence.yDim then
neededPart := 1;
end;
end;
end;
Peter
Hello Peter,
Thanks for your help.
I tried to apply your code to a small model and it works OK. The problem is that when I apply it to a larger model I have the same problem again. The parts stay in the store and are not retrieved.
I am sending the model attached.
Something is wrong and I can't find what it is.
Any help is greatly appreciated.
