Weird situation within tables when calculating lists and sorting
Builder
Builder
Hi!
After several hours of searching, I finally found an interesting phenomenon in the PlantSimulation tables:
When first calculating a column containing formulas and then sorting the table according to certain criteria, all results from the calculation upfront are lost and the gained results are set to zero again.
Is it very difficult to keep the results in the table?
Mak
Re: Weird situation within tables when calculating lists and sorting
Hi Mak,
you can choose the menu "View->Recompute formulas" or just press F5 in the list editor.
Then the formulas are recomputed.
But you're right, it would make sense to do this automatically.
We'll look into this.
Ralf
Ralf
