What is "AttributeExplorer" ?
Hello everyone,
Does anyone can explain briefly what the "AttributeExplorer" is ? And how it works ?
If you have any example I'll take it !
Thank you very much.
Best reagards
O.C
5 REPLIES 5
Re: What is "AttributeExplorer" ?
see example collection - small examples - Information flow - Attribute explorer
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Just a small note: You can load the example collection from the start page.
Version 12 and later: Click the button "Example Models". Then click on "Small Examples".
Version 11 and before: Click the Link "Examples/Infos". Then click on "Examples Collection".
Thanks to both of you !
It's a very powerfull tool. Thank you for letting me discover it and lean how it works.
O.C
Just to illustrate a bit. Based on AttributeExplorers you can easily access nearly any kind of parameter of your whole model in a simple to handle and dynamic way (using queries).
Always consider using the AttributeExplorer!
It's easy, usefull and amazingly powerfull ! Now I can understand your statement "Always consider ..." Smiley Happy
