What method do I write?
I need a production line where the part ends and start another at the same time.
So that I can calculate quantity of pieces in the day / week / month.
I'm new to plant Simulation...
Thank You.
Matheus Ferraz
Re: What method do I write?
you could use an entrance Control in the drain. There you could create a new part on the source e.g.
.MUs.Entity.create(entrada)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
It's not going here.
Att,
Matheus Ferraz
what happens?
Steffen Bangsow
web: www.bangsow.eu
Does not start the next part.
Att,
Matheus Ferraz
can you post your model again to see the problem?
Steffen Bangsow
web: www.bangsow.eu
It worked!!
Thank you very much Smiley Happy
Att,
Matheus Ferraz
