Why my assembly station doesn't work?
Hey everyone,
I met a problem when I was building my assembly station.
The problem is: I want to assemble 1 time of product A, 1 time of product B and 2 times of product C to 1 time of product D. And I set my assembly station as follow:
Assembly table with: MU Types.
And the Frame looks like this:
But when I tried to run the programm, the MU just stuck in the assembly station. Looks like this:
Does anybody know the reason? Thank you very much!
Best regards,
Lee
Re: Why my assembly station doesn't work?
enter into the assembly table only the names, not the complete path (e.g. only rod_6_long)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I tried, but it didn't work.
can you post your model?
Steffen Bangsow
web: www.bangsow.eu
Sure. the Frame shown above is named as "PP_LIFE".
And I used a Method to transfer MUs from other frame directly to the ParaProc station and then to assembly station. Could this be a reason?
the main part (from predecessor 1) you not write in the assembly list.
two entries you need:
Round_stone_White 1
Flat_Gear_Wheel 2
But you have failures in other methods: WH_transport in the frame Main_WH; there you try to move not existing parts...
Steffen Bangsow
web: www.bangsow.eu
Thank you very much! It works. I know the failures exist, it's still not a complete program yet. Regardless of failures, what if I want to assemble 2 times of A and 2 times of B into 1 time of C? In this case, predecessor can only be 1 time of A. So do I need to add another source to be the predecessor?
you can define C as main part (e.g. Main part from predecessor: 3)
Steffen Bangsow
web: www.bangsow.eu
I get it! Thank you very much Mr.Bangsow!
