Why picture can't show in htmlreport?
Hello All,
         Can Anyone tell me, why picture can't show in the Htmlreport object? There is only a "X" which occupied the place.
         Thanks!
5 REPLIES 5
Betreff: Why picture can't show in htmlreport?
Siemens Legend Siemens Legend
Siemens Legend
Dear Erie,
could you please provide more information?
What's about …
  • which object do you refer to get a picture/bitmap from to be displayed?
  • is the picture referenced by HTML anchor element (<a href…>) inside the HTML report "MarkDown"?
  • sending the source code of the HTML report, may be only exceprts of the source code?
  • attaching a sample model?
Best regards
Martin Lemburg
Martin Lemburg
Siemens PLM Software
Digital Industry Division
Product Lifecycle Management
Manufacturing Engineering Software / R&D / Plant Simulation
Siemens Industry Software GmbH, Berlin / Germany
Hi Martin,
     Thanks for your reply!
     For example, I just insert a htmlreport object and make some small changes, and show it, then I can't see the icon and chart in the report.I don't know why.
Siemens Legend
Dear Erie,
Thanks for your sample model.
I loaded the model in version 13 and 14. I had no problems in visualizing the HTML report.
But your last screenshot gave me a hint.
The "broken" images are so called Scalable Vector Graphics (SVG). The Internet Explorer (version 9 and later) is able to load and render them, even if they are stored "inline" in so called "data" URLs.
So a question raises: which version of the Internet Explorer is installed? Or are there specific, restrictive Internet Explorer settings applied?
Could you please try to open the attached SVG file (placed in the ZIP file, since SVGs can't be attached) in the Internet Explorer?
It should look like this:
2017-10-20_09-50-04_C__Users_lemburg_Programms_Documents_Websites_www.acapellala.de_intern_portraits.png
Thanks in advance!
Best regards
Martin Lemburg
Hi Martin,
You're very right, my IE version is 8, you chart attached can't be opened. so I download a IE 11, and then the problem is solved.
Thanks very much!
Siemens Legend
Dear Erie,
Good to read, that you have solved the problem and that you can continue to work with the HTML report!
You are welcome!
Best regards
Martin Lemburg
