Worker carrying part to workerpool
HI All,
I have a situation that eventhough I have entered a "Parts Buffer" in my model, the worker carries away the part at the end of the shift to the workerPool and not in the Buffer. Then the simulation stops!!
Any idea why would this happen?
Thank you in advance
Worker carrying part to workerpool.JPGWorker carrying part to workerpool_1.JPG
8 REPLIES 8
Re: Worker carrying part to workerpool
Can you share the model file?
Best Regards,
Paulo Araujo
Unfortunately I can not share.
try to use one buffer exclusively only for the workerpool, the worker will place his part there and after the break the worker needs to find this part there
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I also had the similar idea and tried it,
but did not work.
you cannot connect this special buffer with another object;
Steffen Bangsow
web: www.bangsow.eu
I tried that as well. Does not work.
@araujopaulo  @Steffen_B I have tried to attached a copy.
I also have a deadlock, when i remove shift calendar from workerpool.
If you can give a feedback would be great Smiley Happy
Bhaiya
the buffer is not the problem;
you are triggering transports by the worker, where the destination is still occupied; so the worker cannot place the parts...
You need to program exit controls (front) where you wait until the next stop is empty; you should also lock the exit of the source, if you transport the parts to station
--> see exit controls
Steffen Bangsow
web: www.bangsow.eu
Perfect. Its working. Was trying it since few days now. Thanks a lot Steffen Smiley Happy
Bhayia
