Worker direction
Good Morning
I need the worker to exit from Station2 and get to Buffer3, but it goes to Buffer2
Re: Worker direction
Hi!
It would seem like the attribute 'destination' on the transporter "overrides" the destination set in the importer tab (Someone a bit more knowledgeble than me might better explain why).
However, I fixed the problem by settin an exit control on station 2 with the following code:
@.destination := Buffer3
@.move
Hope this helps!
