Worker moving multiple parts on Plant Simulation 14.2
I'm trying to move multiple parts with a worker. I used the sample from Steffen Bangsow (https://community.plm.automation.siemens.com/t5/Plant-Simulation-Forum/Worker-moving-multiple-Parts/...). The sample is working well with Plant Simulation 12.
I tried to make exactly the same example on Plant Simulation 14.2 with SimTalk 2, but the worker is moving each part separately.
Did I missed something or do I have to implement it in a other way ?
Please find attached my example.
Re: Worker moving multiple parts on Plant Simulation 14.2
I've found the solution, I missed to set the parameter "Maximum dwell time" at 0:10 (Buffer => Importer Tab).
