Worker - next location
How can I know where is the next workplace the worker is going? When I put the mouse in the worker, it shows where but I want to use this in a method.
For an example, if “the worker is not going to workplace2” then  buffer.entrancelocked := false.
I don´t know how to write this in a method. Do you have any suggestions?
9 REPLIES 9
Re: Worker - next location
Hello Débora,
You can determine the assigned importer of the worker.
The question is which of the assigned workplaces to the importer is the destination of the worker.
local t:table;
WorkerObject.getExportedServices(t);
print t[1,1][1,1].assignedWorkplaces[1];
Maybe someone has a better solution.
Peter
Sorry Peter, I don´t understand what you describe. Could you please send me a simple example using this?
Thanks for your help. Smiley Happy
Hello Débora,
execute the green method and look at the console
(with option Show Print Output).
The picture shows the next workplace Workplace1.
Peter
Thanks a lot!
I´ll use this method!!!!!!!!
Best Regards,
Débora.
Pity, nobody has a better solution.
I happen to have two Plant Simulation versions installed. The 11.0.6 and the 11.2.1.
The strange thing is that the 11.0.6 version has the attribute Destination for the Worker, but the 11.2.1 does not.
This attribute would probably help in this situation.
Not sure what happened through the updates... should this be fixed?
Renato
Well, performed a test here and it does not seem to work. But it would be nice to have this attribute in the Worker just as we have on the transporters. Smiley Happy
Renato
I tried to use this attribute and didn´t work either. Woman Sad
also in Plant Simulation 11.2 the worker has the attribute Destination, but it is not displayed in the dialog of Attributes and Methods (Select an object and press F8), since it is not used by the material flow simulation.
Peter
