Worker problem - loading & unloading
Hello
In the attached model, stations are connected with conveyors.
worker has to load and unload the job only. I have provided load unload time in workplace of station but loading & unloading is not happening. request help to correct this issue.
3 REPLIES 3
Re: Worker problem - loading & unloading
You to unload -/ load from a conveyor with the worker ?
this is not (directly) possible with workers.
Set a station plus a workplace after and before the conveyors
to interact 2 with the worker.
I have already tried that. When we do that the utlisation of machine which we achieve I think is not right.
Why do you think so ?
The stations are conveyor places like
any other conveyor places.
Reduce the conveyor by one place
and set the station processing time accordingly
