WorkerChart controlled by Method
Dear all
I would like to know if it's possible in a method to write a command to open the chart window of the object workerCart :
Re: WorkerChart controlled by Method
sorry I didn't finish my message !
I want to open this chart from another dialog window than the workerchart dialog window.
I tried to use the method viewchart of the object but without success.
thanks for your help
Best regards
Christelle
@Christelle wrote:
Dear all
The answer is easy:
WorkerChart.Chart.Active := true;
Effectively so easy, thanks Peter.
Is it possible to configure the colors of this chart and for example to delete repairing rate or not ?
Hello Christelle,
before the chart is opened you can modify the InputChannels. After the following simulation run, the InputChannels is filled again:
WorkerChart.Chart.InputChannels.cutRow(3);
But changing the colors is not reset by a simulation run:
WorkerChart.Chart.setRGB(1,255,0,0);
Peter
