Workerpool buffer end of shift
Good morning, when the workers ends his workday and they are transporting MUs, these MUs go to the workplace buffer . Well, the problem is that I would like to know if there is any form or someone had the same problem as me and could help me to make a code in order to make that MUs return to the worker in the following day in order to continue the interrupted transport (or work). I attach a model where it is possible to see this problem.
I would be very pleased if someone could help me
Thank you
Re: Workerpool buffer end of shift
You have already an answer:
https://community.plm.automation.siemens.com/t5/Plant-Simulation-Forum/Return-materials-form-workerp...
activate the exit strategy "carry part away", keep the destination empty, Plant Simulation than takes the values in the destination attribute of the parts. You need to set the services of the worker (they dont support the standardService).
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
