10-31-2016 08:59 PM - edited 10-31-2016 09:00 PM
Hi
Im new in the program and i want to know how i can make a worker unload multiple machines and take the parts to a drain? O.o
Solved! Go to Solution.
11-01-2016 04:22 AM
Check this:
Plant Simulation Start page > Examples models > Small examples > Resources > Worker > Carry one part
11-01-2016 01:36 PM
the problem is that in the example the worker only unload one machine at a time and take the part to the drain, but i want the worker to unload multiple machines and take the parts to the drain. For example the worker unload machine A an then go to the Machine B and unload it too, and then take both parts to the drain.
11-02-2016 05:19 AM
If you use the worker only for transportation, I guess the easiest way is actually to use the Transporter object. I do not have an example available of how to let a worker collect MUs from several stations and transport them to a drop point. Makes sense, though.
11-02-2016 03:26 PM
