Workplace control Entrance and Exit
Hello All,
I have a question for workplace control entrance and exit  if I added method both.
I add method at workplace control both entrance and exit to collect entrance time of worker and exit time of worker at workplace. ( worker is assigned by broker)
I assum that assigned worker should be stayed during  work place station's process processing time. however, as soon as assigned worker entrance to workplace, exit method of workplace control  is triggered even workplace station looks working. I would like to get your comments what kind case (error) the exit method of work place control is triggered for debugging?
Thank you
Re: Workplace control Entrance and Exit
There is no known bug that exit control is triggered at entrance.
Can please post your model and the software version.
Kind regards
Karola
