Workplace error
Hello All,
  in my model,after some run it shoes follwing error of workplace. what is the meaning of that error and how can i solve it?Error.PNG
Re: Workplace error
there is a footpath or a connector missing, so the worker cannot walk to dockOut_ASC_2
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Workplace error
Hi Steffen,
thanks for reply. i selected :move Freely within area. Put following method to the entrance control of Workplace
var ObjStation,ObjMU, ObjFrame: object
ObjFrame:=?.Standort
ObjStation :=  ?.Station
ObjMU := ?.Station.Inhalte
ObjMU.Destination:= .Models.Production_System.ALC_1.ASC_2
check attachment for model image.
And i have one more question:
i put two workplace for every stations.1 workplace for worker who come with product for processing and other workplace (for after processing part) worker come there and pick product. How can i do it? Can you plz suggest me any idea?
Thanks in advance
Re: Workplace error
I guess, your path is wrong (pre_assembly_casting_1 in between is missing)
second:
you could use different services for loading and unloading, the Workstations you can restrict to one service, so you can prevent collisions
Steffen Bangsow
web: www.bangsow.eu
Re: Workplace error
thanks first one is working.
for second..i have only one type of worker. in this worker, i can put main service(loading) and supported service(unloading). then i will defined loading service on first workplace and unloading on second workplace.. Then is it working?
thanks
Re: Workplace error
you need also set the services in the exit tabs for the strategy carry part away
Steffen Bangsow
web: www.bangsow.eu
Re: Workplace error
Hi Steffen,
i did small model accroding to your suggestion but its not proper working.Can you check in attachment. In frame there is 3 other stations(singleproc,Singleproc1,and singleproc2) but in singleproc1 and 2 worker use second workstation for loading and unloading part..if there is any error then suggest me.
thanks in advance
Re: Workplace error
more services!!!
Steffen Bangsow
web: www.bangsow.eu
