Write produced parts into TableFile
I have Source - Assembly station - Drain and a number of different types of produced parts. I want to write the number of produced parts into a TableFile. How do I do that?
Grateful for your help,
Malin
Re: Write produced parts into TableFile
you could proceed as follows:
- add a tableFile to your frame
- activate the row index and add all Part names into the row index column
- format the column 1 as integer
Then you can use the entrance control of the drain to count the parts
tableFile[1,@.name]:=tableFile[1,@.name]+1
You need to delete the content of the tableFile e.g. in the init-method to start with a empty table.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hi Seffen,
Thanks a lot, it works perfectly!
Best regards,
Malin
