Z-axis of ASRS
Hello Everyone,
I am trying to model an ASRS which has z-axis as well. I wanted to know how to go about it.
Thanks and regards,
6 REPLIES 6
Re: Z-axis of ASRS
You can set in the transporter the loadbay type track. On this track you can set sensors and can drive on it with a second transporter (your z-axis). Have a look on the 3D HBW library, the ASRS in this library has also the z-axis.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Z-axis of ASRS
Hello Steffen,
Thanks for the prompt reply.
I understood how to model it. However, as you mentioned, i couldn't find ASRS having z-axis in HBW library. If possible, can you post screen shot of it.
Thanks & regards,
Re: Z-axis of ASRS
Here is a picture:
Steffen Bangsow
web: www.bangsow.eu
Re: Z-axis of ASRS
Hello Steffen,
As you suggested, i am trying to create z-axis of ASRS by adding another transporter as RS_z and changing RSU_y loadbay type to track. However, after adding this ASRS in the frame, i am not able to see any z axis in frame.
Part loaded and unloaded from z-axis also becomes invisible.
I have attached the model.
Thanks in advance . . . .
Re: Z-axis of ASRS
for better understanding: what do you mean with z-axis?
If you change rsu_y back to loadbay type store with one place, you see your MU.
If you need one additional axis (e.g. for deep storage operations), you need to load rsu_z on rsu_y and your part on rsu_z. But I guess, in this case the HBW library will not work anymore.
Steffen Bangsow
web: www.bangsow.eu
Re: Z-axis of ASRS
Siemens Legend Siemens Legend
Siemens Legend
I had a look to your model. You need to change the MU animation path name on your RSU_y to "Track". Then Plant Simulation will use this animation path. Please see the attached pictures...
gepi
