an error in method, I don't know where :(
Hi All,
could you please let me know what have I done wrong, that Tecnomatix Plant Simulation displays an error?
I am using V14 currently, code below:
var i:integer
var machineSmiley Surprisedbject
for i := 1 to table_data.yDim loop
machine:=table_data["Machine",i]
machine.procTime:=
table_data["processing_time",i]
machine.recoveryTime:=
table_data["Recovery_time",i]
machine.failures.failure1.availability:=
table_data["Availability",i]
machine.failures.failure1.MTTR:=
table_data["MTTR",i]
machine.failures.failure1.stream:=
table_data["stream",i]
next
My example in an attachment.
Thanks in advance for hints.
Re: an error in method, I don't know where :(
just delete
machine.failures.failure1.stream:=table_data["stream",i]
You don't need to specify the stream in version 14.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you! I was hoping for yor response. Smiley Happy As this example stems from your book, thanks again.
