assembly for different object
I would like make an assembly of 3 manin products a, b,c at assembly station.
MUa is assembled to  object e(3) f(4)
MUb is assembled to object e(2) f(2) g(2)
Muc is assembled to object  e(1) f(1) g (1)
i tried to refer exampleNo 491 https://www.bangsow.eu/detail_en.php?id=491
but could not get a clue.
Any help or simplification in this regard , will be helpful.
cplex
Re: assembly for different object
what was the problem?
Can You post your model?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Here in assembly when i select, BE typen: then it applys the same assembly quatites for incoming main object.
but actually i want to vary assembly objects and its qunatities according to incoming main object.
for example:
when main object is a : assembly should be with e quantity 2 ; f qunatity:3 ; g quantity :2
main object is b: assembly should be with e quantity 4 ; f qunatity:3 ;
thank you
this will not work without some lines of SimTalk. The best place would be the entranceControl (before actions) of the assembly station. Here you need to change the assemblyList (see help, like in my example) or the values in the assemblyList e,g.
if @.name="a" then
	--set new values in the assemblytable
	?.assemblyList[2,1]:=2
	--and so on
end
Steffen Bangsow
web: www.bangsow.eu
thank you MrBangsow
